Re: Re: -h- serial number
Posted by Conrad on January 31, 2001 at 08:07:02 from (207.111.138.151):
In Reply to: Re: -h- serial number posted by Glenn on January 30, 2001 at 18:56:58:
If I am remembering correctly, the H is one of the Farmall tractors where the numbers on the engine block and the serial number plate do match at least most of the time. I have a 1940 M where the two numbers do match.
Post A Followup
: Re: Re: Re: -h- serial number
