Re: -h- serial number
Posted by Glenn on January 30, 2001 at 18:56:58 from (64.196.184.114):
In Reply to: -h- serial number posted by mr foote on January 30, 2001 at 18:05:07:
The engine serial number is located on the right-hand side of the engine just above the distributor/magneto. The serial number from the plate on the clutch housing says your H is an early 1950 model, and the X1 suffix says that your H has a gasoline engine(but you already knew that, ha ha). I don't know if the two should match.
Post A Followup
: Re: Re: -h- serial number
