47 H still stuck
Posted by Dave Sholtis on January 31, 2001 at 15:35:41 from (157.182.212.34):
The H is still stuck. It has had a rear wheel jacked up with three concrete blocks chained to the wheel for better than 3 months and no movement in the motor. There are no less than 4 different types of penetrating oil in the cylinders to incude Kroil. I am currently busy with getting my Cub ready to paint before I bring the H into my garage, but I am trying to get ready for the H which I feel will be a Major project. Do you all have any ideas what I may find when I pull the head? I will pull the oilpan first, and try to see up from below. If there is a froze piston, do they stand out? Or should I see something in the valves?
Thanks Alot-Dave
Post A Followup
: Re: 47 H still stuck
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
