Farmall Tractors Discussion Board
Re: Re: Re: MAX RPM
Posted by mj delaney on January 28, 1999 at 09:03:43:
In Reply to: Re: Re: MAX RPM posted by john d. on January 28, 1999 at 07:36:32:
Good answer. I have an MF 135 diesel too, and know the rpm's I can put from the engine to the baler. I also have about 15 more horsepower to work with. I know it'll run the baler pretty smooth at slightly faster engine rpm resulting in a slightly higher pto speed, and choice baling in dry hay.
I enjoy using the "H" so much I'm just looking for ways to make her more of a pleasure to run.
So, can I still get speed regulation out of the governor say from 1650 to 2050 just by jacking the governor?
Seems to me there's two issues to deal with:
the position of the speed change lever shaft and the speed change lever, and the hi lo idle positions.
Probably more of a trial and error fix is it?
Post a Followup
: Re: Re: Re: Re: MAX RPM
