Farmall Tractors Discussion Board
Re: Re: Re: Re: MAX RPM
Posted by john d. on January 28, 1999 at 09:15:37:
In Reply to: Re: Re: Re: MAX RPM posted by mj delaney on January 28, 1999 at 09:03:43:
If you have a manual, follow the instructions in it for setting top idle speed, if you don't have a manual, consider getting one. It's trial and error to get it where you want it. Once you get the top speed where you want it, you can always move the throttle lever forward to run it at rated top rpm and mark that position somehow.
Post a Followup
: Re: Re: Re: Re: Re: MAX RPM
