Warped Cub Carb
Posted by Stan on February 06, 2001 at 18:19:25 from (12.87.104.130):
IH carb on a 51 Cub
Put in the rebuild kit runs pretty good. As long as you accelerate slowly. Quick move forward and she stalls every time. I noticed gas bubbling out very slowly from the gasket. Took the carb apart again and it looks like at one time the carb had been put back together without a gasket. Now when the two halves come together the spots farthest away from the screws are still apart far enough that the gasket does very little if anything.
Is it possible to bend it back straight or should I try and grind it flat again ?
Thanks in advance for any help !
Post A Followup
: Re: Warped Cub Carb
