Farmall Tractors Discussion Board
Re: Re: TD-6 Talk
Posted by DO on January 29, 1999 at 06:03:19:
In Reply to: Re: TD-6 Talk posted by JW on January 28, 1999 at 09:24:52:
Thank you JW for the reply. Any information at all is always helpfull. The engine runs great, always starts within a half turn or two. Any thoughts on the engine serial # (7-3-Y). Is this a typical number for this engine? I noticed a loose bolt on the backside of the throttlel/manifold linkage; the part that attaches to the block to switch the auxilliary manifold in and out for gas/diesel operation. The only way to tighten this bolt is to remove the assembly from the block (secured with two bolts) . Will I receive any suprises if I remove the assembly? I 'm aware that this is where the manifold gets switches, will springs or something jump out at me?
Post a Followup
: Re: Re: Re: TD-6 Talk
