Re: '46 M Farmall Leaking Hydraulic and Engine Oil
Posted by Phil Auten (TX) on February 12, 2001 at 13:06:59 from (64.217.53.113):
In Reply to: '46 M Farmall Leaking Hydraulic and Engine Oil posted by Tis on February 12, 2001 at 08:36:37:
Tis, The oil pan gasket, rocker cover gasket and lifter cover gasket could all be contributing to oil loss as well as worn rings and valve guides. Replacing a rear main seal on the crank MAY stop oil from leaking there, but there is no guarantee unless the crank itself is in good shape where the seal rides. Another possibility is that the seals in the front of the transmission case need replacing too. Some folks use Hy-tran in the transmission as well as the hydraulics as this is what it was designed for (the Hy-tran, that is). This will sometimes cause seals to leak that would hold back 90EP gear lube. I would start by cleaning everything up where the leaks show and see if you can determine exactly what is leaking and go from there. Good luck, Phil
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
