'46 M Farmall Leaking Hydraulic and Engine Oil
Posted by Tis on February 12, 2001 at 08:36:37 from (208.235.169.34):
Have a '46 M Farmall that is leaking hydraulic fluid and possibily engine oil on the underside between engine and transmission.
Some seals, but not all, were replaced on the hydraulic pump; this has decreased the hydraulic leak. Also, the seal/gasket was replaced on the engine crankshaft; not sure if engine oil is still leaking, because it takes a quart of oil subsequent to pulling a disc harrow 4 to 5 hours.
Question is, where can "all" the replacement seals for the hydraulic pump and possibily other engine seals be found; or, what should be done to correct these leaks. NEED HELP BADDD!! THANKS
Post A Followup
: Re: '46 M Farmall Leaking Hydraulic and Engine Oil
