Re: '46 M Farmall Leaking Hydraulic and Engine Oil
Posted by joe berendzen on February 12, 2001 at 17:27:52 from (216.152.11.99):
In Reply to: '46 M Farmall Leaking Hydraulic and Engine Oil posted by Tis on February 12, 2001 at 08:36:37:
I took out three seals out of my SM this past Friday. The PTO shaft seal, the counter shaft seal, and the transmission input shaft seal. I cleaned the old seals off so I could read the parts numbers stamped into them. I called NAPA and they could order two of them. I called the local Case/IH parts man and he was able to order them all. Another source, a local bearing distributor was able to find two of them. I ended up ordering one from NAPA, and two from the bearing distributor because they saved me about 40%.
Post A Followup
: Re: Re: '46 M Farmall Leaking Hydraulic and Engine Oil
