Clutch pilot bearing on SM
Posted by joe berendzen on February 15, 2001 at 19:11:52 from (216.152.11.76):
First question: Does the SM have a pilot bushing or bearing? Should I replace it while I've got the clutch and shaft out? I haven't notices any vibration from it. If so, will it come out with grease and a dowell like truck pilot bushings?
Second question: Is there a general overhaul procedure for the liftall pump? The cylinder on my three point hitch will gradually bleed down. Is this a problem with the control valve? Any help will be appreciated. Joe
Post A Followup
: Re: Clutch pilot bearing on SM
