Re: Clutch pilot bearing on SM
Posted by Haas on February 16, 2001 at 05:51:07 from (129.37.117.208):
In Reply to: Clutch pilot bearing on SM posted by joe berendzen on February 15, 2001 at 19:11:52:
I suppose the SM is like the M. On the M there is a grease fitting on the flywheel to grease the pilot bearing. You access it through the hole in the bottom of the clutch housing. Only grease it once or twice a year and then only one or two strokes of the gun or you may end up with grease on your clutch. You have to rotate the engine until the fitting appears at the hole. I did not replace the pilot bearing when I did the clutch on my MD. Probably should have. The clutch rebuilder put a new throwout bearing in the clutch(part of the standard rebuild). However, it did not appear to me that it was needed as the TO bearing turned smoothly and had no play in it.
Post A Followup
: Re: Re: Clutch pilot bearing on SM
