Farmall Tractors Discussion Board
706 clutch/pwr.str. problem
Posted by Lloyd on January 30, 1999 at 18:55:39:
I have a 706 diesel with narrow front and 2pt. I used it this past summer to round bale hay. It worked good, but I noticed as I drove on the road if I maintained a slight pressure in one direction on the steering wheel it would move that way without turning the wheels. Once the weather got colder the power steering quit working and the clutch wouldn't engage unless I idled the engine down and went in low gear. As soon as I increased the speed the clutch would release. The steering wheel got real tight and hard to turn. Through all this the 2pt and auxilliary hyds continued to work. I changed the hyd filter and all 17 or so gal of hyd oil. It still doesn't work. Any help would be greatly appreciated. Thank you, Lloyd
Post a Followup
: Re: 706 clutch/pwr.str. problem
