Farmall Tractors Discussion Board
Re: 706 clutch/pwr.str. problem
Posted by RickB. on January 31, 1999 at 05:38:46:
In Reply to: 706 clutch/pwr.str. problem posted by Lloyd on January 30, 1999 at 18:55:39:
I suspect it has a TA? Does the clutch problem occur if the TA is in low? The steering, brakes, and direct drive clutch pack in the TA are all supplied and controlled by a valve body with a small pump bolted to it on the left side of the transmission below the deck. This pump is independent of the pump which supplies oil to the hitch & aux. circuits. I suspect you have problems there, such as bad pump, loose drive gear, stuck spool in the valve body, or a blown gasket in the valve body. You also could have a plugged orfice in the steering supply, along with a bad main clutch. Best to buy a service manual, or get someone with experience to test the MCV circuits.
Post a Followup
: Re: Re: 706 clutch/pwr.str. problem
