Re: Re: Hydraulic pump wont let go
Posted by JLE on February 22, 2001 at 19:43:11 from (12.76.71.247):
In Reply to: Re: Hydraulic pump wont let go posted by DDG on February 22, 2001 at 18:29:55:
The 560 has the same thing, and it is in the regulator valve. It will act the same way. This valve is beneath teledepth valve and the cap is to the rear of tractor. Four caps screws hold cover in place. Remove and then remove orfice and clean.
Post A Followup
: Re: Re: Re: Hydraulic pump wont let go
