hydraulic oil and systems
Posted by tx_patrol_cop on February 23, 2001 at 14:54:42 from (208.237.135.12):
i have just bought a Farmall Super M and had a
couple of questions.
#1. What kind of hydraulic oil/fluid should I use??
#2. Does the PTO shaft and the hydraulic system
have the same resevoir??
I replaced the seal around the PTO shaft and now
the hydraulics won't work. I'm trying to find out
if it might be related to the oil leakage, or if
the hydraulic pump has gone out.
Thanks,
Dave
Post A Followup
: Re: hydraulic oil and systems
