Re: hydraulic oil and systems
Posted by Bob M on February 23, 2001 at 16:15:47 from (66.66.72.246):
In Reply to: hydraulic oil and systems posted by tx_patrol_cop on February 23, 2001 at 14:54:42:
tx - Which oil to use depends on whether your SM has a live (engine driven) or belly (transmission driven) hyd pump. If it's live use HyTran or equivalent hydraulic oil. Use #30 non-detergent motor oil if it's got a belly pump.
The PTO and hydraulic's are independent regardless of pump type. Chances are you're hydraulics are out because the reservoir's low on fluid.
Post A Followup
: Re: Re: hydraulic oil and systems
