Re: Another hard starting C
Posted by Rich Cota on February 26, 2001 at 05:12:06 from (198.56.12.237):
In Reply to: Another hard starting C posted by Rick on February 25, 2001 at 18:48:18:
Rick, take your starter switch off and check it out. Sometimes the terminals inside are corroded up or loose. If corroded, clean them , if loose, replace the switch.Make sure the terminals are straight also. Sometimes from overtightening the wires on the top terminal the terminal gets twisted and then will not get hit squarely when engaged.Good luck!
Post A Followup
: Re: Re: Another hard starting C
