Is this proper governor operation?
Posted by David A on February 26, 2001 at 11:58:19 from (198.24.4.11):
On my Super A, moving the throttle up does not start changing engine speed until about 1/4 of the way up. After that it is smooth. Same thing coming down. Lower quarter does not reduce speed smoothly.
Under load, the governor seems to regulate OK.
Does this indicate a governor that needs cleaning and lubing?
After clean and lube do I need a tach to setup upper and lower idle speeds? Or can these setup adjusters just be left untouched?
Thanks,
David
Post A Followup
: Re: Is this proper governor operation?
