Posted by Grandpa love on April 21, 2017 at 18:28:22 from (172.58.172.154):
Well. Got small, welded on pulley off PTO. Got shaft splines cleaned up nice. Pulley went on fairly easy. 1st issue one of the bolts that tightens pulley to shaft will tighten a bit then come loose. Stripped!!? So longer bolt? Bigger bolt? 2 nd issue. Now when tractor is out of gear ,running there is a loud rubbing ,metal to metal noise mash clutch and it stops. 3rd issue. If you put pulley on until it's flush with end of PTO shaft it hits the lift arm bracket. Is it possible to put shaft in too far? Should tranny be in netural when shaft goes in (will that matter ). Also ,I'm guessing that if mower works then the engagement leaver is in slotted pulley. Thanks for any and all help. Kevin in Central AL. ( But I did mow 1 lap around yard !!!! ,Small steps. Lol)
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
