amp reads negative.
Posted by joefarmer on March 06, 2001 at 09:58:18 from (24.23.11.91):
Amp meter is running reverse on 12 volt system. with lights on it is -10. i am under the understanding i need to polarize the generator to reverse this correct?? I am clueless as to the voltage regualtor and its connections for this.
Post A Followup
: Re: amp reads negative.
