Re: Re: amp meter reading neg. revisited
Posted by joefarmer on March 07, 2001 at 06:13:31 from (24.23.11.91):
In Reply to: Re: amp meter reading neg. revisited posted by ltf in nc on March 06, 2001 at 20:54:04:
yes it has generator and yes it charged fine prior to the incident.it was realized when you turned the switch on the amp read pos. which was draining battery. the battery would be dead after every use. the amp meter stays on 0 when the switch is turned on now. the generator has been rebulit and it has new voltage reg.
Post A Followup
: Re: Re: Re: amp meter reading neg. revisited
