Farmall A Hydraulics re:rod from side of engine to the back lift
Posted by Murray in N.S. on March 09, 2001 at 04:46:29 from (142.177.83.55):
Could anyone supply a picture of the left side of a Farmall A, re; the piece of metal that comes off the shaft on left side and goes to the lift arm that raises and lowers, an example would be plowing. I have not been able to get the tractor to plow. After viewing some of these pictures on the board, which didn't really show that much of the hydraulics, I do know that some where along the way this one is badly bent,(the rod from side of engine to the lift rm. Also the piece on side of engine has been welded many times and pieces of iron added on , that I think probably I should start new and replace the two parts. the system works okay other than trying to plow, the plow is in and out of the ground, sort of annoying. thanks for any assistance. Murray
Post A Followup
: Re: Farmall A Hydraulics re:rod from side of engine to the back lift
