Re: WD-9 SPLITTING
Posted by a common problem on March 09, 2001 at 10:29:02 from (155.226.0.241):
In Reply to: WD-9 SPLITTING posted by Greg Robinson on March 09, 2001 at 09:31:48:
Have seen this many times where the rear engine seal is leaking. Replacing the seal is not the total answer. Most of those seals are bad because the rear main bearing is bad and has beat the seal enough to make it leak. Replacing the rear main bearing is most likely what you will have to do to fix your leak on a more permanent basis.
Post A Followup
: Re: Re: WD-9 SPLITTING
