WD-9 SPLITTING
Posted by Greg Robinson on March 09, 2001 at 09:31:48 from (216.43.28.248):
I have a WD-9 that is in the midst of restoration (or demolition, if you like) It starts runs and moves well enough, however it has a tremendous oil leak. The oil leaking is engine oil and it is coming from around the "Flywheel area"...I'm assuming the rear main seal is bad. I'm in the process of pulling the engine but I can't figure out how to do it. I have done the obvious: remove sheet metal, linkages, wires, lines, radiator etc. but I can't tell how the enine is connected to the transmssion/clutch. Any help, suggestions or horror stories would be greatly appreciated.
Thank you in advance for your time.
Post A Followup
: Re: WD-9 SPLITTING
