Re: WD-9 SPLITTING
Posted by clark on March 10, 2001 at 16:26:51 from (64.12.103.23):
In Reply to: WD-9 SPLITTING posted by Greg Robinson on March 09, 2001 at 09:31:48:
you dont have to remove the engine to replace the rear seal and the rear bearing's. the clutch is coupled to the trans shaft woti a 2 piece coupleing and and the clutch and flywheel come out the bell houseing cover, it amy be easier to di it by takeing the bell cover off,the engine weighs around 2500lbs and takes a hefty shop crane..remove the oil pan to gain access to the bearing's
Post A Followup
: Re: Re: WD-9 SPLITTING
