Re: Steering problem on H
Posted by The Undertaker on March 11, 2001 at 16:07:16 from (64.40.66.190):
In Reply to: Steering problem on H posted by Farmall Ed on March 11, 2001 at 13:35:33:
Farmall Ed: Just finished mine a few months ago. Had to replace the bushings, top and bottom, also the pivot shaft, pivot shaft bearing and spacer. You may well find the bolster itself has been cut out by the bearing. The entire weight of the tractor front end rests on that bearing. If it goes then the bolster will be worn, also the pivot shaft where it butts up against the bolster circular boss will be cut in a nice clean circle. I constructed a crib for the front end to rest on after jacking it up. You'll find bushings will be much easier to replace if you pull the front bolster out to work on it. After cutting out the old bushings you should get some engine assembly lube to install the new ones. Be safe in securing the tractor and block rear wheels and put on brakes. The Undertaker!
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
