Farmall Tractors Discussion Board
Re: Re: Re: CUB throw out bearing
Posted by John Healey on February 03, 1999 at 16:50:50:
In Reply to: Re: Re: CUB throw out bearing posted by Rob on February 03, 1999 at 02:46:24:
Not true Rob. The grease fitting is in the metal retainer that holds the carbon bearing. There is a weep hole opposite the fitting for excess grease to squeeze out. There is no path for grease to get onto the spline ( or slide as you call it ) . And besides you don't want to grease the spline as graese holds dirt and grit and carbon dust which will gum up the works.John
Post a Followup
: Re: Re: Re: Re: CUB throw out bearing
