Re: Re: Re: Re: Cylinder Pressure
Posted by Denny Frisk on March 21, 2001 at 12:13:50 from (12.4.181.2):
In Reply to: Re: Re: Re: Cylinder Pressure posted by Bama Binder on March 21, 2001 at 10:20:50:
What He actually wants to say is that an engine with 95 psi cranking compression can be lugged down to lower RPM without damage than one with High compression. The Hi PSI engine would probably detonate and blow holes in the engine. But to make any noticable difference You'd have to increase the compression ratio like from 6.5:1 to 7.5:1 or so. You will reach a point where your fuel will not support the higher heat and compression and will detonate & destroy your engine. With these old engines like the H's & M's you would have to modify the engine for much higher compression, and lug the snot out of them down to like 500 to 800 RPM at full load. The higher comp. pressure actually does give more Horse power.
Post A Followup
: Re: Re: Re: Re: Re: Cylinder Pressure
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
