It wasn't a rod knocking, but listen to what I found. M
Posted by jim on March 21, 2001 at 17:21:37 from (63.11.249.164):
History lesson, go with the boards first thoughts!I had piston slap and boy did I have it. Pulled the pan and guess what I found piston parts, one chunk about the size of a quart jar lid and the two sisters half dollar sized.All fit together and not a lot of secondary bits in the pan. Oil pump looks great and all the other pushers and pullers are clean as can be expected on a 60 year old tractor. Next step-I know the answer, any suggetion or direction, can I buy 1 piston rebuild kit? I will check the other 3 for good measure.
Where would be a good place to find these parts?
By the way I can't believe the parts fel into the pan.
Help me out ya'll
jiM
Post A Followup
: Re: It wasn't a rod knocking, but listen to what I found. M
