Re: It wasn't a rod knocking, but listen to what I found. M
Posted by Mike S on March 21, 2001 at 21:12:41 from (64.12.102.37):
In Reply to: It wasn't a rod knocking, but listen to what I found. M posted by jim on March 21, 2001 at 17:21:37:
If you want to make a cheep fix get a used piston and a new set of rings. Be sure to measure your old piston to see if its 3 7/8 or 4 inch. If you have good oil pressure the rest of the motor should be ok. Good luck
Post A Followup
: Re: Re: It wasn't a rod knocking, but listen to what I found. M
