Re: Anti-freeze in oil- always problem?
Posted by peterc on March 21, 2001 at 18:05:14 from (64.30.151.55):
In Reply to: Anti-freeze in oil- always problem? posted by DAve G on March 21, 2001 at 16:47:27:
keep an eye on it ,if the anti freeze shows up again you need to look for the source. The heads on A B C tractors are noted for not sealing well on the push rod side of the head. I use copper coat on the head gaskets on these tractors. I know it is not recommended to use sealant on head gaskets but I make an exception for these tractors.
Post A Followup
: Re: Re: Anti-freeze in oil- always problem?
