TD25BP Dozer 817B engine overheat and won't start.
Posted by Larry on March 23, 2001 at 16:50:38 from (216.138.40.47):
TD25BP dozer overheating and does not want to start. This dozer started getting hot just moving it not under a load. Had the radiator cleaned and rodded out checked the pump.Now it is hard to start also,if it starts it will blackstack and miss for about 2 or 3 minutes, then it will clean out and run fine. Checked injection pump (R&D)changed filters,no air in radiator,no oil in water,new turbocharger.Before I rebuild engine I was wanting to see if someone had another idea.
Post A Followup
: Re: TD25BP Dozer 817B engine overheat and won't start.
