Farmall Tractors Discussion Board
Re: 6V or 12V polarity
Posted by Daniel on February 04, 1999 at 16:36:20:
In Reply to: 6V or 12V polarity posted by john on February 04, 1999 at 13:42:24:
John,
Positive or negative ground doesn't matter to as long as your consistant. When converting to twelve volt most people use a GM Delco one wire alternator with internal diodes. These are set up for a negative ground system, hence the need to change over the tractor. All modern cars use negative ground and it has no effect on spark strength. By the way, coils have a positive and negative terminal, too. Alot of times this connection is not reversed as it should be.
Post a Followup
: Re: Re: 6V or 12V polarity
