Re: Farmall C problem
Posted by Haas on April 01, 2001 at 05:40:06 from (129.37.117.79):
In Reply to: Farmall C problem posted by Tim Mattson on March 31, 2001 at 17:45:14:
Does gas run out of the drain hole on the carb air intake? If it is doing that when the tractor is shut off, your float is sticking, or is set too high, keeping the gas from shutting off causing the tractor to flood. The carb problem will cause the black smoke. The white smoke sounds like a coolant leak. Could be a blown head gasket.
Post A Followup
: Re: Re: Farmall C problem
