Re: Re: Governor on a farmall H
Posted by Farmer Bob on April 01, 2001 at 22:45:17 from (208.49.10.156):
In Reply to: Re: Governor on a farmall H posted by Dan on April 01, 2001 at 22:29:30:
Dan is right on...one way to determine if the adjusting block is off is to loosen the screws connecting the trottle shaft to the connecting rod housing. With tractor running and throttle set to idle, stick a long screwdriver under that end of the tube that goes back to the carb and gently raise up on the tube. If the tractor idles down, your adjusting block is more than likely mis-adjusted.//FB
Post A Followup
: Re: Re: Re: Governor on a farmall H
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
