Pin in water pump assembly
Posted by BTD on April 05, 2001 at 06:24:34 from (207.48.192.3):
I've read before that I need to remove the pin from the bracket at the front of my water pump assembly to get the thing apart. I have the nut off, but the pin will not budge. It does not look at all corroded and I have let so much PB-Blaster soak around the pin that it drips out by the large brass? nut behind the bracket. Should it be that hard to remove this pin? Thanks! -BTD
Post A Followup
: Re: Pin in water pump assembly
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
