Re: Pin in water pump assembly
Posted by Haas on April 05, 2001 at 14:42:30 from (129.37.117.48):
In Reply to: Pin in water pump assembly posted by BTD on April 05, 2001 at 06:24:34:
Maybe this trick will work. I've used in on wheel bolts that are stuck. Screw a nut half way on the bolt(or pin) you want to remove and then screw another bolt of the same size into the remaining threads on the nut. You can then use a hammer on the head of the second bolt to break it loose without fear of damage to the threads.
Post A Followup
: Re: Re: Pin in water pump assembly
