Re: Farmall M 12 Volt Conversion using a generator
Posted by Bob M on April 08, 2001 at 07:59:19 from (66.66.72.246):
In Reply to: Farmall M 12 Volt Conversion using a generator posted by Red Rider on April 07, 2001 at 18:29:59:
A 12 volt generator conversion is pretty straightforward and works fine. One option is to have a auto electric shop rework your existing 6 volt generator to 12 volts, then install a suitable 12 volt regulator. 2nd option is to obtain a 12 volt generator and replace the existing 6 volt unit. If you choose this option, make sure you get the matching regulator for the 12 volt generator - a mismatched regulator could ruin your new generator! Wiring is relatively simple too. You can re-use the existing wiring harness if it's in good shape. Only wiring change is the generator field wire (connected the field control terminal at the light switch on the original 6 volt setup), will instead be connected to the "F" terminal on the new 12 volt regulator. Also don't forget you will need to add a ballast resistor in series with the ignition coil primary. Or you can replace the existing coil with a 12 volt coil.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
