SMTA Fan Pulley
Posted by Gary G. on April 12, 2001 at 03:45:57 from (208.223.205.166):
Can't tighten fan belt. Adjustable fan pulley has a hair line crack. That is the threaded side you turn to tighten the fan belt. Can't figure out how to remove threaded side of pulley. I have the radiator & fan blades off. The shop manual I have doesn't help. Will I have to remove the complete water pump to get at the shaft & pulley? Any help/comments will be appreciated.
Post A Followup
: Re: SMTA Fan Pulley
