Re: SMTA Fan Pulley
Posted by Bob M on April 12, 2001 at 05:02:51 from (192.232.119.194):
In Reply to: SMTA Fan Pulley posted by Gary G. on April 12, 2001 at 03:45:57:
Gary - Can you turn the moveable half of the pulley on the adjusting threads? Have you removed the setscrew from the moveable half?
Unless the hub threads are boogered up, you should be able to unscrew the moveable half off the fan hub once you remove the fan blade.
Post A Followup
: Re: Re: SMTA Fan Pulley
