Re: Sediment bowl wont drain
Posted by The Red on April 14, 2001 at 05:08:10 from (12.75.196.20):
In Reply to: Sediment bowl wont drain posted by JDM on April 14, 2001 at 04:47:05:
JDM disconnect the line at the bowl and turn on the gas and see if it is flowing OK out of the strainer assembly with the bowl intact. If it flows OK, then it sounds like you have a partial obstruction in the fuel line. If not, then you have crud in the valve chamber on the strainer. Let us know what you find!
Post A Followup
: Re: Re: Sediment bowl wont drain
