Re: Sediment bowl wont drain
Posted by J in Pa on April 14, 2001 at 07:24:35 from (63.79.69.60):
In Reply to: Sediment bowl wont drain posted by JDM on April 14, 2001 at 04:47:05:
JDM, i know the frustation that you are having. these sediment bowls have a strange way of acting. first remove the bowl and see if you have full flow from the tank. second, put the bowl back on and see if it fills. if it doesnt fill, just loosen the nut at the bottom till it does fill. then tighten it again. i've found in most cases this is the way that it works. you have to get the air out of there before you get any kind of flow of gas.its an air lock. third, if the gas isnt flowing properly from the tank to the bowl, there may be dirt or something in the shut off screw blocking off the flow. the flow from the tank to the bowl isnt a straight shot. there is a dog leg in there that can trap dirt and little pieces of stuff. i have seem pieces of lead in there and other derbis that when you shut off the gas supply, it will jam itself on the other end of the shutoff valve causing a block. the only way to make sure its clean it to drain the gas and remove the whole sediment bowl and take it apart and clean it. the shut off can fool you. it might look clean, but it might not be. forth, make sure you vent is working on the filler cap.and use clean fuel. and make sure you tank is clean. ok. i hope one of these suggestion work for you. just my 2 cents worth
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
