Re: Sediment bowl wont drain
Posted by JDM Update on April 14, 2001 at 07:38:11 from (206.74.34.75):
In Reply to: Sediment bowl wont drain posted by JDM on April 14, 2001 at 04:47:05:
OK Since I last posted a little bit ago,I went out and went through everything again.Looks good.With the bowl off,gas flows fine.put the bowl back on and tighened the nut,opened the valve,no gas.Loosened the nut gas flowed,butleaked.Tightened just enough to stop the leak.Gas flowed fine.Ran for about 30 minutes doing a little bushhogging,er mowing(correct police),just shutoff.Again I blew air,stuck it to my mouth and blew,(nasty tatse still in my mouth),gas flowed and ran good until I finished with no problems.I am suspecting I have a venting problem of some type or posibly a problem with the rubber hose conversion I made recently.I did that suspecting the steel lines were clogged,but apparerntly they werent.I seem to have had a series of problems with this thing,one thing lead to another and so on.guess Ill change the assembly next week and see what happens then.Thanks fellers!
Post A Followup
: Re: Re: Sediment bowl wont drain
