706 with no steering - maybe TA and brake problems too
Posted by andy on April 14, 2001 at 18:46:29 from (66.43.222.16):
The steering on my Farmall 706 gas is not working. The steering wheel turns but does not turn the front wheels. Once in a while it will actually work. I think that the brakes and TA are affected too. I have never had any problems before like this. I did replace the PTO clutch disks last fall. Some of the plates were worn down enough that the PTO was slipping. I did drain the oil from the transmission to pull the PTO out. I put all of the oil back. I did not and have not ever changed the hydraulic filter down on the lower right side of the transmission case since I have owned the tractor. Is there a possibility that the PTO clutch plates filled the filter up? Will a restricted filter cause these problems? Like I said ... it works at times and then it won't work. I have pulled the filter out and will replace when I purchase a new one. Any advice will be greatly appreciated.
Post A Followup
: Re: 706 with no steering - maybe TA and brake problems too
