Re: Sediment bowl wont drain
Posted by rhudson, temp fix on April 14, 2001 at 19:15:35 from (63.81.99.149):
In Reply to: Sediment bowl wont drain posted by JDM on April 14, 2001 at 04:47:05:
JDM,
you probably don't want to do this but... i have a self-propelled haybine that the tank coating is flaking, and stopping inlet to bowl. i took some galvinized electric fence wire about 4 inches long with a thigh bend at the lower end. unscrew bowl assembly out, push the wire up into tank, (with bend down). quickly screw bowl back in. usually the wire vibrating around will keep a clear path for the fuel into the bowl. i bet nobody else farms with junk like me.
Post A Followup
: Re: Re: Sediment bowl wont drain
