Re: What's wrong with my friend's IH 1206 Turbo?
Posted by R.David on April 15, 2001 at 16:26:41 from (207.44.65.61):
In Reply to: What's wrong with my friend's IH 1206 Turbo? posted by Alberta Mike on April 15, 2001 at 06:20:55:
Water or condensation freezing could certainly cause your problem. If the fluid hasn't been changed in a while it would be a good idea. If that can be ruled out the problem is likely in the multiple control valve or the pump mounted behind it. That pump operates the TA, the power steering, and the power brakes. There is another question related to this on this page of the discussion forum titled: 706 with no power steering... the hydraulic systems of the two tractors are the same. I posted a follow-up to that one also. There might be some information there that can help you. Good luck. If you have any questions you can e-mail me.
Post A Followup
: Re: Re: What's wrong with my friend's IH 1206 Turbo?
