New Farmall Owner Update
Posted by Doc on April 15, 2001 at 21:55:28 from (216.177.136.131):
After getting over just got the new tractor home and now it leaks jitters, things are going okay. Got the belly pump out and the new seal in, haven't got the pump back in yet. Darn thing is heavy! One spring in the pump, identified in the I&T manual, as the hold up spring was slightly collapsed. What will this harm if anything? Pump had some scoring but it is serviceable. When I looked at the tractor and had it running, ammeter showed charging. was going to charge the battery, saw it in backwards, hokked it up with pos. ground and now shows discharge. Did polarize the generator, have since found some bad wiring, haven't tackled that yet. Thanks to all for answering earlier questions. I am looking forward to working on this old girl, and also helping others through this board. Doc
Post A Followup
: Re: New Farmall Owner Update
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
