Re: New Farmall Owner Update
Posted by Terry H on April 16, 2001 at 17:21:27 from (209.83.58.139):
In Reply to: New Farmall Owner Update posted by Doc on April 15, 2001 at 21:55:28:
Regarding your electrical problems, had the same situation. Recently bought a super A, had the battery in backwards, and many other electrical problems.Paint in all the connections, and a bad battery cable. cleaned and replaced all the problem areas and hooked up the battery with positive ground. after polarizing the generator, every thing now seems to work except still have a discharge situation. when checking the generator with a volt meter, it is putting out 7.5 volts, but with reverse out put, that is negative output from the A terminal. Any advice as to what to do next?
Post A Followup
: Re: Re: New Farmall Owner Update
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
