Re: Installing a 12 volt, 10 SI alternator under the hood of a Farmall M
Posted by Jim on April 17, 2001 at 07:14:27 from (198.247.178.202):
In Reply to: Installing a 12 volt, 10 SI alternator under the hood of a Farmall M posted by Lllab on April 17, 2001 at 05:36:03:
I have put a lot of 10 SI alternators on M's And H's. All I do is turn the generator bracket over drill the hole out to 3/8 and mount the alternator on the front part of the bracket and find or build the top bracket. The biggest plus is that this method uses the original belt.I have never had the bracket break or bend. Some times on the H's you will need to heat and bend the generator bracket up to get the hood on.
Post A Followup
: Re: Re: Installing a 12 volt, 10 SI alternator under the hood of a Farmall M
